calamus
Jun 19, 2014Explorer
First check for spider webs in the line. Second I always have to light the stove and let it burn for a minute or so, Then try again. Make sure you are careful with open flames and propane. If the stove and furnace light most likely you have a block in the gas tube of the water heater check it out good.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
