Old-Biscuit
Jun 19, 2014Explorer III
Check for 12V DC at gas solenoids while spark electrode is firing.
Red wire from ECO to solenoid then to black wire (Grd)
Also check that all grounds are clean/tight
Main gas orifice is not plugged
Spark electrode gap is 1/8" and no cracks in ceramic insulator (unplug red wire on ECO to gas valve. Stick a fiber washer (some type of insulating material) between electrode and ground rod....fire unit. If you see a spark jumping from the ceramic to the ground rod or bracket, replace the spark probe
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
