stew47's avatar
stew47
Atwood water heater only heats with 120volt
My model is gc10a4e Atwood. This is on a new to us 2010 crossroads and to be honest I didn't try it when I bought it. They said it worked so... I think they only used on electric as well. I do know I have 12 volts leaving inside switch and that's as far as I made it.
  • Update for all. It works. I suppose it's operator error. I kept turning it on when water was already warm. I used meter and wiring diagram. Realized thermostat was open. Ran water until thermostat closed and it fired. I'll clean some connections to be sure but I think I just had head in clouds because vacation wasn't going well. Truck in shop for u joints :(. Anyways thanks.
  • Can you hear it spark? Have you tried turning on your gas kitchen burner to insure air is purged from the line? Can you smell gas near the burner tube? If your sure the water heater is getting gas and it's sparking then you might try and remove the spark assembly (easy, one screw removal) clean the ends with emery cloth and make sure the two probes are within the correct distance of each other (easy to bend).
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
