Circuit breaker has nothing to do with spark/ignition on that water heater.
Circuit breaker would be for 120V AC---electric element if you have a combo water heater
Spark/ignition/propane flow are all 12V DC
IF you have SPARK and if you have GAS FLOW but no ignition:
1)Poor electrical ground....Green wire above T&P and Black wire behind gas valve
2)Electrode assembly mounting screw...provides ground and if electrode is sparking to it then no ignition ---adjust electrode
3)Dirty electrode......clean with emery cloth
4)Electrode NOT engulfed in main flame...should glow red
5)Flame spreader on end of burner tube not 'square' with tube..gas doesn't spared out correctly and spark can't light it
IF main flame is good strong and blue when you light it off with BBQ lighter then:
Good 12V DC voltage supply..........good grounds.....correct placement of a clean electrode should resolve issue
