Katdaddy's avatar
Katdaddy
Explorer II
Mar 07, 2026
Atwood water heater problem
I have something strange going on with my water heater. It is an Atwood G6A-8E propane heater. On our last trip it would start like normal and heat the water just fine. After that it would not fire again. I could turn the power off overnight and start the heater later at night to get a shower. Same thing each time, initially runs great then nothing. I have replaced the gas valve, power board, igniter and the thermostat. It is still doing the same thing. Any suggestions welcome.
1 Reply
  • That’s a tricky one. If it runs fine once and then won’t refire, it could be something like the ECO/high limit switch or even a grounding issue. Might be worth checking the wiring and connections closely, especially around the thermostat and board.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 09, 2026
