dougrainer
May 29, 2015Nomad
What you have is either
1. You have a rubber LP line that feeds the W/H is pinched somewhere. If the W/H was in a slide, that would be the most likely cause
2. IF the other LP appliances operate OK, then the line feeding off the main LP line is partially blocked between that T and the W/H.
Last, you are correct, this is NOT a Bad LP solenoid. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
