Kelvininin
May 29, 2015Explorer
Chris Bryant wrote:
It almost has to be external to the unit- I would trace and inspect the copper line back to the manifold, and probable disconnect to check for oil in the line.
The only gads valve fault I can come up with would be the regulator built in to the valve going bad. Not something I have ever seen or heard of, but there's always a first time.
I guess that will be my next step. I know there is a kink in the copper tubing but heater fired fine our fist trip. I may replace the supply tubing all together to eliminate it as a potential issue.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
