BFL13
Aug 13, 2019Explorer II
Old-Biscuit wrote:BFL13 wrote:
I know Atwood has a different tank material from Suburban so it does not need an anode in the drain plug. Hers has that plastic plug for an Atwood. I don't have the model number, but it does have 120v and propane. Trailer is about 10 years old. More later if required. Be a few days.
Atwood Aluminum'
Suburban STEEL Tank...which has a glss-lining sprayed inside hence the andoe rod requirement
Trailer 10 yrs old and is combo electric/gas
If 6 gallon.....GC6A-10E Model
If 10 gallon....GC10A-4E Model
Replacement tanks available for each
NEW complete water heater replacement available
I have a line on a GC6A-7E from a 98 Southwind Class A. Would that fit in the hole in the side of the TT her GC6A-10E goes into? Lots of room inside the TT where the WH goes, so it is just the access in the side of the TT that matters AFAIK. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
