Old-Biscuit
Aug 13, 2019Explorer III
Cut out openings
6 gallon
12 1/2"H X 16"W X 19 1/2"D
10 gallon
15 1/2"H X 16"W X 20 3/4"D
6 for 6 and 10 for 10
Her newer version can be replaced by the earlier version
AC side needs 120V AC to on/off switch then to separate set of T-stat/ECO on backside of water heater tank then to element
OEM ON/OFF is also back there
DC side for propane....12VDC to On/Off switch then to thermal fuse to t-stat (then OEM wiring to control board to eco to gas valve)
Atwood Water Heater Info
6 gallon
10 gallon
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
