mando_man's avatar
mando_man
Atwood Water Heater Will not Ignite or Stay Lit
I'm having a problem with my Atwood water heater. It attempts to ignite, but then fails. I've replaced the TSTAT, ECO, thermo fuse (circled in green). You can see and hear the spark when it's attempting to ignite, but never catches (circled in blue). What I do see sometimes is ignites, but I see a small flame for a second or two where it's circled in red which does not seem right. Any thoughts?
Picture of Water Heater
  • The original post was confusing. Was the ignitor replaced? If not, that should be first on the list.
    Next make sure all the connectors are clean and seated especially the connector array, upper right.
  • 1. Small flame indicates a clogged orifice. Remove the orifice and clean with spray carb cleaner and compressed air.
    2. Also indicates LOW or marginal LP gas pressure. Light the Stove/Range burners all 3 or 4. They should have a full blue flame
    3. When it tries to ignite, tap on the gas valve with a hammer. IF the flame then comes ON, your gas valve is bad.
    4. If the W/H is in a slide room, then the rubber gas line may be pinched. Doug
  • Start by checking the ground on the gas valve. It is hidden behind the mounting bracket.
    Check continuity on the TWO gas valve coils. They should read the same resistance.
    I don't care much for the wires at the circuit board being so tightly twisted.
    Forgot ask does your other appliances work OK?
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
