Gjac
Mar 30, 2016Explorer III
The manual that phays posted tells you how to trouble shoot the board and the other components of the systems. If the board is green you can see all the components and look at the backside for any burned tracks on the board and the front to see any components that look burned or melted. The potted board you will have to check with your ohm meter. I would check and clean all the connects first especially the grounds and igniter to see if that helps.
