Artum_Snowbird
May 21, 2016Explorer
Not sure if you have done this. There is a wire that goes in the front of the water heater with a fusible link that is designed to cut off the power to the gas relay if the fusible link melts because of a fire outside of the burner.
My fusible link was not melted, but the connection at one end of the fusible link was rotten and corroded preventing anything happening. Like you, I took the board in and it tested fine.
Once I peeled off the shrink cover over the link, I could see the problem right away, and remade the connection with a new squeeze connector and then it all worked fine.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
