Old-Biscuit
May 21, 2016Explorer III
CRMW wrote:
I just hooked up the orifice directly to the regulator bypassing the gas valve and I can get a much better flame. Leaves me to believe the gas valve itself isn't letting the gas flow properly.
Hooked up orifice to regulator......????
Which orifice....the one that is screwed into gas valve?
Have you 'measured' the gas pressure at the WH gas valve??
Have you checked that BOTH solenoids on gas valve are getting energized?
Weak LP Regulator could be issue IF other propane appliances (furnace/stove top burners on HIGH) are not functioning properly
OR
It could just be bad/weak solenoid(s) on gas valve or a clogged Main Orifice.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 08, 2026
