wa8yxm
Jun 22, 2015Explorer III
It EMPTIED the tank..not possible.
But if the thing does not hold pressure, (Water hater off but water lines Charged with 45-50 PSI) if it holds with the heater off you have a different problem
But that TPR valve (Temp Pressure Relief) is at the top of the tank it is not possible to empty the tank from that port.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
