jwchenault
Jun 22, 2015Explorer
I suppose if the pump doesn't shut off at the proper pressure it could build up enough pressure to relieve out the t&p valve until the tank is empty! However IMHO the more likely possibility is that the t&p valve is bad. and its a quick and easy replacement. If the pressure switch is at fault it is a bit more involved unless you just replace the whole pump.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
