pcantin's avatar
pcantin
Atwwod Water Heater Questions
Hi there.
I have an Atwood water heater (DSI-6)in my class C. The problem is that I have no idea how to use it! I know that it runs on gas, but I can't tell if it runs on electricity as well. I have looked everywhere and can't find a model number.
In addition to the remote switch at the sink, there is an on/off button on the back of the heater where the wires go into the unit. What is that switch for? I am not sure of the procedure to get this unit running.
Any help on this would be appreciated.
  • Model number should be on the frame around the outside access.
    It sounds like it is a combination DSI and 120 volt.
  • from your description... i think you have one that is supposed to run on gas AND electric. turn the switch at the outside in the door for the water heater OFF to turn off the electric element ( when you are not plugged in or when you are paying for electric) and turn on the remote switch ( does a little red light come on just above it? that indicates the auto light feature is there...and trying to light the pilot. of course you must have the gas on ....and abouve all... since you never ran this...make sure the tank is FULL of water. The best way i know to be SURE is to manually open the popit valve on the out side ( red circle ring around it ...with a lever) and watch out for water to come out.
    if the electric feature does not work it may well be burnt out from being turned on with out water in the tank.
    feel free to pm me for more info if this did not solve your problem
