Davidlee64's avatar
Davidlee64
Auto Transfer Switch?
Does anyone recognize this transfer switch? 2004 KZ Sportsman 5th wheel, OE Generac genny, OE Parallax 7345 converter. I would have to cut the shelf in order to remove ATS cover to see internals.
  • Great ! I found the documentation for this ATS on the Parallax web site, in the Archives Tech Docs section. PPS Line Generator Switch. Thanks all for pointing me in the right direction.
  • D.E.Bishop wrote:
    To answer your question simply, NO. It would be nice to know what is prompting you to ask, do you have a problem or just want to know the answer.
    My reason for asking is curiosity. I like to know how things work. I put a new converter in recently, and just serviced the gen-set. I turned off the shore power and unplugged it. I left the c/b's on the gen-set turned off prior to starting. I didn't want to cause any damage to anything. Information on this RV is lacking on some items so better safe than sorry. I do want to confirm that things work like they are supposed to.
    I did suspect it is from Parallax as that is the manufacturer of the original converter setup but I didn't see anything resembling it on their site but didn't look in archives either.
  • To answer your question simply, NO. It would be nice to know what is prompting you to ask, do you have a problem or just want to know the answer.
  • That switch is part of the Parralax Converter box and chassis. This link will show what it looks like removed from the Chassis. Inside is a RELAY with the Shore Power and Genset wires connected. Then there are the 3 wires that leave it and connect to the 120 Breaker panel. Doug
    To look at it, just remove the 4 screws holding the Converter chassis to the cabinet and pull it out as a complete unit. Remove those top 2 screws and the ATS cover comes off.
    http://www.parallaxpower.com/ats301-transfer-switch-ats301
  • It looks very similar to a Parallax ATS 301, but the label isn't identical. On the ATS 301 the label reads "line/generator" and the orientation is different, whereas your label reads "line\generator". That leads me to believe it's a Chinese knockoff. I did a Google search and found some that look very much like the photo posted.
  • Anonymous's avatar
    Anonymous
    Not applicable
    Was it some sort of malfunction that prompted you to open the switch or just getting ready for the inevitable? It looks like a no-name generic that I had with worn contacts. The dealer identified it as being made by Magnatek. It had no diagram inside the cover. I found it easier to get a new one with a time delay. The old one did not have a delay circuit and had a tendency to chatter causing the contact points to burn. The delay allows the generator to get up to speed first.
  • enblethen wrote:
    Remove the cover, and look at the schematic on inside of cover which should have manufacturer.
    That will be my next step.
  • Remove the cover, and look at the schematic on inside of cover which should have manufacturer.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 07, 2026
