pianotuna
May 06, 2017Nomad III
Hi,
The 951 is running watts for the air conditioner only. I have seen up to 1900 running watts on the same air conditioner in a campground on a 30 amp circuit where I was deliberately forcing the Magnum inverter to do voltage support (I do not recommend doing this, as the Magnum had a catastrophic failure later in the summer).
I think the power factor on the Dometic must be pretty lousy. For the resistance load of 1525 watts @ 114 volts equals 13.3 amps, and load support doesn't trigger.
I know my Microwave draws 1591 watts so perhaps I'll add it to the mix.
The reason I am testing in this location is because I know from past visits that the 15 amp shore power is extremely weak with large voltage drops under loads such as a toaster.
mvas wrote:
You stated 951 Watts for the "motor".
Is that the Running Watts or the Starting Watts ?
The Starting Watts for a motor, can be 2X to 3X the Running Watts
2 x 951 Running Watts = 1,902 atarting Watts
3 x 951 Running Watts = 2,853 Starting Watts
Power Factor is usually a smaller issue,
while the In-Rush Starting Watts is the larger issue here.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
