pianotuna
May 06, 2017Nomad III
Modus Operandi
air conditioner without load support with 5 minute wait between testing phases with a run time of under one minute. To reduce surge the fan on the air conditioner was allowed to come up to speed before the compressor was started. Fan speed was set to low.
no load voltage 118
fan only wattage 223 inside RV
fan only wattage 233 before autoformer
air conditioner wattage inside RV 945
air conditioner wattage before autoformer 941 (kill-a-watt meter)
voltage before autoformer 108.1
voltage inside RV 117
Observations. As the air conditioner continues to run wattage inside has crept up to between 1200 and 1300 watts.
Addenda after 30 minutes the wattage has crept to 1425. Input voltage is at 101.9 and inside the RV is 121 volts.
Conclusion--it may be better to not use the Magnum with the autoformer when in a campground with 30 amp or better. But where I don't have easy access to the breaker box, I'll choose to do so running at 12 amps (80% of full capacity).
no load voltage 118
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
