MrWizard
May 06, 2017Moderator
Ok PF correction for the autoformer and the magnum
But the A/C is not PF corrected
You measured 951 at the a.c. Coming from the magnum, including the 33 amps load support?
, if so your saying shore power was only 500+ watts, because the magnum was supplying 400+ watts, that is curious
But still over 1000va being used by the ac,
Your awful close to the power limit you set the magnum to use
I'm sure this is why magnum was inverting, if it did not invert the usage would exceed its own calculated VA for amps used with associated voltage drop off incoming voltage
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
