Hi Naio,
In June I was at a campground and did not yet have the autoformer. It was hot and there was the usual voltage sag (103 with only the roof air running). I used the Magnum hybrid inverter/charger load support feature and found that I could "force" it to do voltage support. It generally took about 200 watts from the battery bank to do this. My solar system was replacing those watts. So, in a sense, I should have been billing the campground for about 1.2 kwh's of "my" energy. Or about......16 cents!
I do not plan on advertising the fact that I'm using an autoformer--just as I did not advertise that I had to use the hybrid feature of the Magnum to support their "code minimum" wiring.
Naio wrote:
Gdetrailer, you seem to have missed the part of my post where I advocated PAYING FOR the extra 16 cents worth of electricity.
Why does that not surprise me?
