Given that Sola Basic works as advertised which I have documented, then it solves the issue of low voltage supply being delivered to the park.
That is what is going on at my brother's cottage. Unloaded voltage was 113 by ten am.
SoundGuy wrote:
In reading this thread it seems many if not most believe low voltage is a park issue and while at times this may be the case it's just as likely the power grid system feeding the park is where the real issue lay, in which case there's not a darned thing the park owner could do about it anyway. :R
SoundGuy wrote:
Rubbish. Here in Ontario service is provided by local utilities that in turn are fed power by Hydro 1 ... during the hot summer months especially, low voltage brownouts do happen across large sections of the province, primarily here in S Ontario where most of the population lives. Load on the system at this level is well beyond the capability of the local utility to "fix". :R
