Trumpeterb's avatar
Trumpeterb
Automatic awning issues
I have a Dometic 17’ automatic awning on my TT, and it now extends and retracts very very slowly, and sometimes stops alltogether. My wife will have to hold the button down while I manually help it along. I am not sure if this might be an issue with the awning motor or not. I do know the battery is not very good and doesn’t hold a charge well...but I am plugged in most of the time, so I haven’t replaced it. Anyone know if a weak battery will affect the awning even if plugged into electric? Other suggestions?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are two or three suspects depending on how you count. actually one more but rare it is
    1: Voltage.. 1A low battery or bad connetion (Are you plugged in when moving the awning this helps 1B bad connection (Circuit specific) on the Awning system
    2: LUBRICATE, LUBRICATE Alas. I do not know the lube points on your awning but and they make it hard to find a few points that might need 'em (As in impossible) but Lubricate. where possible
    3: Brake not fully releasing (rare)
  • Sounds like battery issue, lack of voltage, rather than motor failure. Try using truck battery, with jumper cables, hooked direct from truck to RV battery.
    Jerry
  • Connect a voltmeter right at the motor terminals and watch the voltage during retraction. On mine the voltage was 9.1V during retraction with a fully charged battery due to inadequate wiring.
    My Carefree had terminals at the motor for emergency retraction.
  • Yes. I lubricants all of those twice each year. To listen to the motor, it just sounds like it is running out of gas. That was why I wondered about the battery.
  • Have you tried cleaning and lubricating the hinges and sliding parts?
  • If you're uncertain, hook up 12 volt power directly to the motor. From a known good battery.
  • Yes. My awning practically came to a standstill because my battery was dead. New battery and it worked just fine again.
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 07, 2025
