3_tons
Oct 13, 2022Explorer III
Alraz24 wrote:
My Ac will not run off generator. It runs fine off shore power. When trying to run off generator the AC will try to come on and then shut down to only fan working. Generator will still run, but produce no power and AC fan will run, but no compressor(just warm air)then later it will produce 120 volts again but, no ac compressor. Thought it might be automatic transfer switch so I wired a female plug end to the out put of the generator and plugged my shore power line in to it. AC and generator all runs fine. Do I need a new transfer switch?
Thanks
Mike
If you have a pass-thru type inverter, it may be (as it’s designed) disqualifying the generator power (seeing the generator source as substandard), but only when the heavier load compressor attempts to start, this while the air conditioner fan remains operable…
3 tons -
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
