Bobbo wrote:
Roger10378 wrote:
wa8yxm wrote:
The ATS has two inputs normally marked LINE and GENERATOR
Two types of ATS One is a relay race (Whatever is first is only) But I doubt that's how yours works... More likely GENERATOR controls it.
If there is power on the GENERATOR input. than that is used.
NOTE: DO NOT SWITCH UNDER LOAD
Turn off all loads before plugging in or turn off main breaker so there is no 120 volt load when you plug in.
I have to disagree. Most likely if there is power on the line then it is used. When line power is not there then it will switch to the Gen position. There should be instructions with the switch that will tell you how it works.
I have to agree with wa8yxm. I have never seen one with LINE priority that wasn't mis-wired. Every one that I have ever seen, wired as the instructions call for, when the generator starts, the ATS switches to it regardless of what the shore power line has.
don't know if thats miswired or just the way the person wants it set up. I don't understand why you would want your generator to take over from your shore power, but I dont know anyone with generators either. every Transfer switch I have seen is a set up to supply power from an inverter or from shore power and you need to stack another to add a input from genny or shore power that gets sent to a second one that choses between one of thoes and the inverter, unless there making a three input that I haven't seen yet. but for me I would want the shore power to be the ultimate pripority, then the genny, if neither one of thoes is hooked up then the second ATS will automaticly pick the inverter. now this could all be me just not knowing the reason why you would want a generator to have priority but I dont see a reason for it off the hand.
