AllegroD
Apr 30, 2014Nomad
Just because the converter is not putting out does not mean it is it's fault. Have you tested the 120V plugs? Are you actually getting 12oV to the socket where the converter is plugged into? I have not seen where you have traced the 120v back to either Gen or SP. Before spending more money, I would verify that power is getting to the converter.
If your converter is proven bad and not under warranty, call Randy at Best Converter. He will get you a good fit for your rig. I like the PD 9200 series.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 07, 2026
