Mikeborny wrote:
Ok, I replaced the coach batteries on Saturday and brought home and plugged into my house. I have a 30 amp rig. I have nothing but the fridge running. This morning, I checked the aux. batteries and it has lost power again. It is now down to 4 lights out of 5 when I push the Aux. battery button.
What else should I be looking for that would drain the batteries?
Why are you running the refrigerator when you are now turning the new batteries into "toast"? Turn it off and keep it off until you your battery problem figured out.
The refrigerator can easily kill the new batteries since they are not getting charged. Is the switch "on" to keep moisture from forming? Turn it "off"
Since you drove to the Ford dealer the generator would have slightly charged your old 6v house-batteries. Since they are sulfated and shot they only have very little capacity. Maybe 15 minutes or less. The guy only checked the batteries with a meter and saw better than 12.7 volts and claimed them good. Hogwash!
Did he pull them out, fully charge them, and do a load test? It would have taken most of the day. Check your bill for a "Load test".
Have you checked the circuit-breaker for the converter/charger? Cycle it off and on. Check the fuse panel to see if the fuse blew. The converter/charger may also have it's own fuse to check. When your "idiot meter" read only 4 lights it was indicating your batteries were discharging from the refrigerator being turned on and no charging coming from the converter/charger.
Have you picked up a multi-meter to check the house-battery voltage at the battery-terminals yet? It's an absolute necessity. While unplugged read the voltage at the battery-terminals. 12.7 volts would be fully charged for the new pair. I expect you to see something lower.
Plug into shore-power and make sure the "Disconnect" switch is pushed to on. Did your hear a click sound from the solenoid to indicate the batteries are now connected? Check the voltage again at the house-batteries. The voltage should rise from the initial voltage to either 13.6 volts, or 14.4 volts (bulk charging from your 3-stage charger.
If the voltage does not rise to at least 13.6 volts either the charger is not working, or the solenoid failed to connect the house-batteries.
At any rate your camping season will not start until your system is working.
