dobbr's avatar
dobbr
aux diesil tank transfer pump?
Upon researching an aux diesel fuel tank for 2015 Ram 2500 cummins,
I have decided on RDS rectangle bed tank. Fuel can be transferred
to the oem tank via a gravity flow kit, which splices the main fuel filler tube. (plus vents) Therefore it is necessary to exit the cab turn the valve allowing flow to the main tank.
I would accept any input as to which small in line pump, may be installed, eliminating the need of stopping to activate the flow of the aux tank to the factory tank. I have numerous additional elect switches that have not been accessed
Thanks
  • If you are going to set up a gravity feed, why not just install a 12 volt veton fuel valve?
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
