anchor wrote:
All fixed! The person that offered 15-30 minutes to keep the pos. cable disconnected hit it right on the head. Got new gas cap, light still came on. As I said the 30 min. seemed to do the job. Looked for the person that suggested the 30 min. -- thanks. Also still cannot find the house battery. Does not seem to be in the crowded engine comp. We do have an Onan generator however. As I mentioned--this is our 5th RV and the smallest in 25 years. We also have a 36' Fiver. Thanks to all.
Unless you take it out on the road for at least THREE full warm up/drive cycles you really will not know if the problem is fixed.
It takes multiple drive cycles before all the different sensors get tested and are reported as ready to the GEM.
Ran into that with one of my vehicles concerning a oxy sensor that was getting weak.. Reset the codes and would take two or three days and the light would pop back on..
New sensor, reset the codes and no more light.
Check engine lights just don't randomly turn on without a reason.
If it really was the gas cap, the light WILL EVENTUALLY go out on it's own when a good cap is in place. However your chassis should have a separate gas cap indicator light on the instrument cluster (my 2003 F250 has a separate Fuel Cap Warning light)..
PLEASE, READ the following link concerning the evap system.. Pay attention to POST #10..
FUEL CAP WARNING LIGHT
