prichardson wrote:
Ditto. Running any engine on a higher octane fuel than what the manufacturer recommends is a waste of money.
Not always. Ive been putting 110 octane fuel into small engines for 25 years. People often overlook how excessive engine load can cause knocking as well. Its not strictly about compression ratio. Swear to you i currently have 8 month old 110 octane inside a little 1989 TW200 motorcycle. I ride this bike every single day up and down the same hill where i live. While it does not need 110 octane, i promise you there is a performance gain. The bike makes 15 HP i hold the dang thing wide open and ride it like a maniac. It runs stronger on race gas. Its even mixed to 40:1. Only running it because i ran out of regular 91 and need to use up the old gas.
Another thing people dont consider is that yes the manufacture recommends 87 octane. Trailer sits for 6 months. What octane do you think that gas has degraded to? I always put 91 into my trailer for this reason.
Lwiddis wrote:
Why not just follow the engine manufacturer’s recommendations?
Because with very basic modifications you can increase efficiency. I have never owned a vehicle and left it completely stock. For example the big ole Donandson air filter on my 7.3L. It filters better and flows better. Engine manufacture would most likely recommend i buy a motorcraft filter im guessing. I like OEM for some things. Aftermarket for others. The manufactures engine tune is junk. You can increase power and fuel economy if you dont follow the manufactures tune.
