wa8yxm
Dec 02, 2020Explorer III
The awning may be Stuck, Sometimes the Rib will work it's way out and wrap around the shaft (If that's what happened you will clearly see it.
Option 2 is not so nice and a 400 or 500 parts bill plus 1 hr labor. so I'm not going there (Seen it once)
There are two manual overrides described in your owner's manual.. ONE reuires a jumper battery or other 12 volt source and a cable that should be in the Owner's bag (One rig I worked on it was not) the other a screwdriver and damages the wiring.. but that's the court of last resort (What we had to do) 2 days later a pro replaced the motor... TWICE. But since yours started to roll up I think you are better off than he was.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
