Trumpeterb's avatar
Trumpeterb
Awning question (last one hopefully)
Ok...awning off, new fabric on, end caps replaced...now, it is a 17’ Dometic awning, and the research I found said that the spring should be tensioned 10 turns (clockwise—spring is on the left side). My question—after turning it 10 times (assuming that is the right number), do I reinstall the awning ina rolled up position, about a foot or so away from the camper, therefore the spring would have 10 turns of tension in the closed position? Or do I reinstall the awning in the fully extended position, therefore placing 10 turns of tension on the spring when the awning is fully extended? Sorry for all the awning questions....I am new to all of this.
  • In my experience wrapping anything with electrical tape tends to hold water in rather than keeping it out. Just a thought.
  • Thanks for all the help and advice through my various posts about awnings. I finished the job this morning, and everything worked out great. The awning is working as it should now, and there is brand new fabric to boot. Turns out the barrel connectors were all corroded, so I cleaned those off and used some dielectric grease on that connection, and wrapped the entire thing in electrical tape to try and help shielded water in the future. The tension spring was also not set correctly, so I corrected the tension as well. Happy to say that now it works great! Thanks again all.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
