Here's the deal, we have an awning that is in really good shape with the exception of one issue. Across the top it looks like it could have cracked or whatever but the 2 layers is getting water betwee...
Can you remove the awning and put the damaged side so it is facing the bottom when it is opened. this should prevent water from from collecting between the halves. Then tape the damaged area.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
