MEXICOWANDERER's avatar
Jun 16, 2016
Axle To Axle Check
Even a long piece of heavy mono-filament fishing line works for this...
  • This takes 2 people
  • Straighten steering wheel (hopefully this means straight ahead travel for your rig)
  • Hold a conference with your friend. You need to define the meaning of exactly where "center" is on the front and rear hubs
  • Then measure exactly center to center front to rear hubs one side
  • Then go around and measure that distance on the other side
  • You can also do this on a multiple axle travel trailer.
  • Not a good idea to use mono-filament. It will stretch when pulled tight and not be accurate. We always used thin bare wire for that purpose. The wire must be flexible enough to pull out any curls.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
