Hi all, Looking to source parts for an axle upgrade. I have a bent axle so I want to replace it and do an upgrade with mor ryde parts. The Mor Ryde CRE 3000 lists 33 and 35 inch wheelbase. I'm meas...
best measurement is hubface to hubface, the part that the wheel is bolted flat to, usually the brake drum with the studs poking out. Center-to-center will bring in variables like wheel/tire width that is not unique to the axle. Easy to just call them after you take many measurements including the leaf spring perch, which you can do center to center.
