- wa8yxmExplorer IIIThe answer is not as simple as yes/no
At DC the answer is NO
At RF the answer varies with frequency. - johnhicksExplorerI've read that charging lithiums with an ordinary alternator can smoke your alternator. Investigate before doing that.
- Chum_leeExplorer
wanderingbob wrote:
I believe that I was taught that all things being equal, that stranded wire would carry more current than solid wire ? Is that true or am I being misled ?
You were taught correctly, but the difference is negligible. What matters more is the operating temperature of the wire. The cooler the wire is, generally, the more current it will carry. (less voltage drop) Stranded wire, because it has more surface area per foot than solid wire can shed or gain heat more easily than solid wire depending on the ambient temperature and the insulation. Stranded wire has much more flexibility (resistance to vibration) than solid core wire of similar gauge, that's why you generally see its use in aerospace, automotive, and industrial applications.
As the temperature approaches absolute zero (-460 degrees F) wire conductors approach zero resistance. They become superconductors where current flows with little to no voltage.
Chum lee - wanderingbobExplorer IIGuy next door sez that I should not let the alternator on my truck charge my lithium while driving . Is he a dummy ?
- theoldwizard1Explorer II
Dutch_12078 wrote:
A shunt is a small resistance inserted in line with the load
Small in "value", but large in size. - StirCrazyModerator
other way around solid wire will carry more current than stranded wire of the same size due to air gaps between the strands and stuff. - Grit_dogNavigator III
jkwilson wrote:
Tvov wrote:
I was always told that solid wire conducts / allows more electricity / power. That is why houses are wired with "romex", solid wire, instead of stranded wire like extension cords. Considering how difficult romex is to work with, everyone would prefer stranded wire if it would work better.
Well, that is the simple explanation given to me by electricians!
Solid wire is cheaper to make and easier to connect in household wiring. Stranded wire is better where flexibility is important such as lamp cords or in vehicles.
Thank you for being our mythbuster this morning for the electrically challenged. - jkwilsonExplorer III
Solid wire is cheaper to make and easier to connect in household wiring. Stranded wire is better where flexibility is important such as lamp cords or in vehicles. - TvovExplorer III was always told that solid wire conducts / allows more electricity / power. That is why houses are wired with "romex", solid wire, instead of stranded wire like extension cords. Considering how difficult romex is to work with, everyone would prefer stranded wire if it would work better.
Well, that is the simple explanation given to me by electricians! - valhalla360NavigatorThere is a small difference in max current. The bigger issue is solid wire is more prone to failure over time.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
