RJsfishin wrote:
Snowman9000 wrote:
When you say you will remedy the problem of only having a 120v outlet... You mean you have a basic 15A outlet and you will be adding a 30A or 50A outlet later? I want to make sure you don't think you need to add a 240v outlet, because your trailer is only 120v, no matter if it is 30 or 50A.
Huh ?? A 50 amp RV service is 240 volts !
I had to look it up. You are right, thanks. I never thought far enough into it.
http://www.myrv.us/electric/pg/50amp_service.htmProbably the problems we have read about involving fried RV components at 240v comes from mistakes involving 30A services.
