wwest
Jun 24, 2014Explorer
Disconnect the wire/cable from the chassis battery/system isolating device to the house battery(set). Then connect that cable to the input of the inverter(***). When underway connect the shore power plug/connection to the inverter output.
*** <800W,---- open the fridge CB, 1000W or more, you have enough to power the fridge. Your converter will be powered via the inverter thus the house battery(set) will be properly and safely charged.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
