kaydeejay
Jun 24, 2014Explorer
am1958 wrote:That Winegard outlet may only be rated for 8 amps, that's 96 watts.pianotuna wrote:Hah, I knew I'd be missing something...
The fridge will draw about 325 watts--that requires about 33 amps, which means the outlet for the winegard will not provide enough current.
It's back to the simple solution then, buy ice...
Thanks all...
You will not power much with that, even if you do wire it correctly.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
