am1958
Jun 24, 2014Explorer
smkettner wrote:
You can mount the inverter behind the fuse/breaker panel. Splice into the main battery feed for 12 volts. Then use a $59 transfer switch to send power down the one circuit. Just make connections, no pulling wire.
Prowatt 15a switch
Oooooohhhh... That looks sexy and it sounds like it might be the answer... Thank you!!!!
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
