BTPO1
Jun 24, 2014Explorer
Huntindog wrote:
So long as you REMEMBER to do everything perfectly EVERYTIME!
The reason that this is illegal just about everywhere, is that the life you are putting in danger is someone else's.
This is not a unsafe act such as not wearing your seatbelt.... Where the life you are endangering is only your own.
The types of wiring you are proposing are so dangerous, that I won't even discuss how to do it.
Just that it must be done perfectly EVERY TIME..
The problem is that if one forgets, and a linemen doesn't happen to work on your line at that time,,,, nothing bad happens. Then a lacadasical attitude sets in, and somebody ends up DEAD.am1958 wrote:camperpaul wrote:
What you are doing at home is so dangerous the cord you use is commonly called a "SUICIDE CORD".
Back-feeding the wiring in your house can result in injury to or death of the linemen who are working to restore your power.
DON'T DO IT!!!
I agree with your response on this issue. Even if the OP does open the breaker there is no way for him to know if it is actually open. To know for sure you have to see an air gap which you cannot see with a small breaker. As a retired utility operator/electrician I can only hope that the OP changes his system to an ATS, back feeds into the power grids can and DO KILL. JMO
I did say "after shutting off the master". By that I mean I isolate my house from the rest of the power grid. The linemen are safe.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
