- fprestoExplorerCongrats on getting it out. You could have saved the Tow Truck driver a lot of grief on here if you had included the info that is was your decision to not pull from the back.
- CapnCampnExplorer IIIThanks for the update & congratulations on the success!
- Kate_and_EdExplorerThanks for the help! We used dirt, rocks, wood, carpet piece, Traction’s mats and in the end 4x8x16 cement blocks to roll it up on! We have reasonable nice front lawn tow service would tear it up pulling it out from back so didn’t go there. Laid cement blocks all the way to fence gate so when ready to take her to a shop to work on jacks can go. While she is gone will configure block so under tires and jacks. Side note shop ordered parts from Newmar and very long wait.
- jaycocreekExplorer IITraction mats get very good reviews...
- jjrbusExplorerHave tried several different methods to get unstuck. The issue with using wood in any form is if stuck due to water the tires will slip on wood. Water and mud acts as lubricant! Tiny gravel, sand anything added to gain traction on the wood.
I carry scrap wood leveling blocks. I paint them and add very coarse sand while the paint is wet. Color choice is up to you LOL
https://www.youtube.com/watch?v=NSRxhvufvmw - C_B_Explorer II
theoldwizard1 wrote:
That is a really poor tow truck driver. Usually they just back their truck up on to solid ground, let out more cable and pull.
A snatch block will allow the pull from a different angle.
Call a different "Heavy Duty" tow company.
C.B. - notevenExplorer IIIscrap plywood under the tires
get a winch double lined and hooked to the rear axle housing itself. Don't pull on brake lines and wiring there is no strength there :)
be gentle and take your time. Don't let the winch operator drag stuff that will break on the ground.
steer the front past the ruts from the rear. - JoeHExplorer III
beemerphile1 wrote:
I got out once by jacking the vehicle and putting firewood in the hole. Since we were camping firewood is what was available.
If you have leveling jacks it should make it real easy.
Yep-- did that once too - MEXICOWANDERERExplorerI have a 30 ton 4" diameter 30' long braided nylon strap that I can no longer lift. Quicksilver at 18,000 lbs snatched a fully loaded propane bulk truck out of a ditch. Boy did it ever stretch the strap. I tried three times, the last one almost bumper to bumper. Quicksilver has a 100 pound Pintle hitch. Heavy rigs are a challenge. Good luck to you!
- theoldwizard1Explorer IIThat is a really poor tow truck driver. Usually they just back their truck up on to solid ground, let out more cable and pull.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
