Matt_Colie
Oct 19, 2020Explorer II
Kate,
I just went through a similar with a multi-ton sailboat on a trailer in my back lot. It was supposed to be gone by August.
Your problem:
If the ground is soft, jacking will be really tough, but with enough planks to spread the load out you can do it. We did.
Our axle was also on the ground so just towing was not going to work.
We ended up doing it all.
When there was room, we pushed stones under the tire to support some of the weight.
We jacked enough to get the axle up on planks and dug an exit ramp that we also put also put planks on.
We had to rig tackle to a hard point (tree) because the truck could not get enough traction on the wet ground.
Finally we got it out and now all I have to do is get in a 5yd dump of something to fill in the holes.
Matt
Your problem:
Matt
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
