wa8yxm
Oct 19, 2020Explorer III
Ok How are your leveling jacks and are they all the way down on the ground. Two sets of directions
If Leveling jacks fully retracted and in contact get a bottle jack and some 2x12's (2 or 3 feet long and I'd recommend a harbor fregight 12 ton (or bigger) Air/Hydraulic with a compressor to power it)
LIft so the levelign jacks are off the ground and 2x12 under them. This one should be 3 feet or longer Centered. Use it to lift the axle as far as you can and fill in the hole.. Let it down till you can plank under the wheels and drive off. Only suggestion I can make May take a while.
I carry a 160 PSI 6 gallon blow hard (Compressor) and 12 ton Air/Hydro jack.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
