MEXICOWANDERER
May 27, 2013Explorer
This is the kind of durability and value that once was. If a part did not work, you took it apart, and fixed it with a small tool kit. On an obsolete diesel model a cam lobe went flat. I built up the lobe with Allstate 275 and then ground it down to best look like the lobe on the other cylinder. It started within 5 seconds of cranking and ran like a champ. Pushed a 20 kw Lima generator to a little over 12 KW at 12,000 feet altitude. On 13 gallons a day. A clue as to why I get so cranky with some of this throwaway gizmo junk.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
