dennislanier's avatar
dennislanier
Backup camera problem
Posted this earlier on the Class C forum but did not have much luck so I will try it here. I have a 2004 Jayco Class C with a visor-mounted rear camera that stays on whenever the ignition switch is on. It worked fine a couple of weeks ago but today will not come on at all. I checked all the coach fuses and even the fuses inside under the instrument panel. I assume it has a fuse somewhere but none of them are specifically marked as such. Does anyone have any suggestions for troubleshooting this thing? I have not yet taken anything apart but will try that if necessary. Any input appreciated.
  • Thanks for the replies. Looks like a project for later on. Leaving on a short trip in it today. I was hoping to get it working before we left but that's not gonna happen. Hopefully I can figure it out without buying a new one.
  • Dakota98 wrote:
    Visor mounted monitor ? Is it built into the visor or just mounted on it. Is it hardwired to monitor?
    The monitor is attached to the visor with screws. The cable is attached to the monitor INSIDE the visor. I will have to take it apart when I get time to check the connections. The cable runs from the visor (Monitor) to behind the door pillar. Don't know how it is routed from there.
  • I think I would unplug and check for power. If it has power, you don't need to look for a fuse no more.
  • Visor mounted monitor ? Is it built into the visor or just mounted on it. Is it hardwired to monitor?
  • We had one on our MH that went out. They said there were 3 components..... 1) the camera, 2) the monitor and 3) the cable. In our case, a mouse had gotten in and chewed up the cable. :) Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
