joe0508
Apr 23, 2014Explorer
backup camera
I resently purchased a backup system for my rv.The screen has the slightest static in the monitor.I have the camera hooked up to the monitor and the monitor powered to a dc plug in the cigarette plug ...
fcooper wrote:I did have the generator on so maybe that was it.I will try the battery thanks.Also i dont know if the two ar related but if i roll up/down my power window the screen will turn completely off and show black and white lines rolling.joe0508 wrote:westend wrote:I will try that but what if the charging system is the problem.What would i do than?I have tryed it in the dc plug with the motor off and get the same results.Dont no if that would be the same concept.
If it's possible, power the camera and monitor directly from the battery with the vehicle off. That will eliminate any interference from the vehicle's charging system as a cause.
If you were not running inverter/converter, overhead lights, etc, it may be a bad monitor. I'd still try it hooked directly to a battery that is not connected to anything else. If it still has the problem, I'd be asking for a replacement.
Fred
