Cstoliker
Aug 31, 2013Explorer
westend wrote:
Yes, you need the pad ears to slide in their holders and, yes, good brake fluid in the system. What some may not realize is that this era of larger Ford chassis had significant problems with calipers sticking, It happens especially when rotors and/or pads are worn to the end of their lifecycle. There is something about the geometry of the caliper cylinder and the mating seal surface that causes them to stick in the extended position. I've repaired/serviced more than a dozen Ford trucks with the same problem. The ultimate fix was to replace the caliper and they should be done, at the least, in pairs.
So the old warn pads may have been the cause. I'll still do my line pressure test to confirm but that makes sense. Did the bad calipers you've seen from this stick randomly while other times work normally?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
