BFL13 wrote:
"all your learning" seems to have missed this--see 5.2.2
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
Our man Mex the battery guru, says this applies to all AGMs, not just Trojans. Lifelines are even more so where they can accept more than 20% in Bulk and ISTR have a "minimum charging rate" too.
Note your solar controller shows amps with loads and while camping you still have loads. You are trying to see only 1 amp for 200AH of batts, so your "parasitic loads" will be close to that. Hard to run the Rv and disconnect the batts entirely while they are being charged! Easy at home.
Rolls likes a 25% charging rate for Bulk but says you can use a lower rate but it will take longer. Wade down half way to the AGM instructions--very interesting!
https://rollsbattery.com/public/docs/user_manual/Rolls_Battery_Manual.pdf
"It is recommended that the initial charge current
is set at 20% of C/20 of the battery bank (min 10% / max 30% of C/20) in order to fully charge the batteries within a reasonable amount of time."
There are several mfg's as you state that show an ideal Charge rate for depleted batteries. This is reasonable to charge up in good timing & to take advantage of AGM lower internal resistance. They state the batteries at a highe charge rate. Trojan claims 20A Max Charge input. Rolls states 10% Min to 30% Max Charge.
The great thing about me is... I can learn new things!
The other great things is we're both not wrong in a way. I think were onto something here...ha ha Let's dig in...
Just spoke to Rolls technical dept. (Very knowledgeable) & you've made a point that I need to re-mention... Sulfating batteries & a doubled edge sword of what your doing.
5-15% Shallow discharges will require,
1-2 times per YEAR, bringing a cycle to 20%-50% to allow a higher current charge, as you mentioned, to keep sulfation down.
Here is the doubled edge sword:Yes, Sulfation will be kept down w/routine deep discharges as you do. However, Doing it anymore than necessary shortens life cycles. It's a balance that tips in shallow discharges favor.
Based on their statements today your doing way too many intentional discharges for the sake of keeping the sulfation down AT THE EXPENSE OF CYCLE LIFE.
To sum: Your keeping sulfate at bay w/frequent deep cycles BUT your shortening their overall life by doing so anymore than necessary. There is no need to, routinely, discharge the batteries to below 75% SOC to see the 20% recommendation.
If shallow cycling You Only need deep cycle a couple times a year.
The winner: frequent Shallow Discharges w/2 20-50% annual deep cycles to see High currents will keep sulfate down & get you the longest life.
Quit discharging your batteries below 75% SOC so frequently. I need to make sure to discharge mine below 75% SOC a couple times a year. We'll both get the long life we paid for. It's a balance.
