Terry78's avatar
Terry78
bad inverter?
I just got my trailer delivered 2 days ago. When I plugged it in to shore power the inverter was humming loudly and clicking on and off
This cycle would happen about every 10 seconds.
I was told on another forum to charge the battery so I did.
This time it still clicked and hummed but the Lights didn't dim as
They did before. When I unplugged shore Power i have NOTHING.
No lights no water pump no heater no information panel. Nothing.
What is causing this nightmare in my new home? Granted its 35 years old... But still! Any ideas?
  • Terry78 wrote:
    Thank you for the information. I am going to replace the ring terminals
    Tomorrow. I will be checking this. Great info.
    You NEED a multi-meter to test things.
    Replacing parts based only on a guess often turns out bad.
  • I'm a little confused with the wiring on this trailer. It has a big red wire with a fuse. It has a big white wire and a big black wire. Also a small black
    wire. I am pretty sure red is hot. But no clue on any of the others.
    These wires run from trailer to the battery on the trailer
    What they ARE depends on what they are connected TO.
    Sounds to me like you need some onsite help from someone with a bit more experience.
  • Hi Terry78,
    You need to get a meter of some kind.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
